[mapguide-trac] #233: Xml Parser and Utf-8 support
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jul 26 04:59:06 EDT 2007
   Reporter:  ksgeograf  |       Owner:
       Type:  defect     |      Status:  new
   Priority:  low        |   Milestone:  1.3
  Component:  Server     |     Version:  1.2.0
   Severity:  minor      |    Keywords:  utf-8 encoding xml byte marks
External_id:             |
 When constructing an Xml document with Utf-8, it is common to insert the
 Utf-8 byte-order header: 0xEF, 0xBB, 0xBF before the leading encoding tag:
 <?xml version="1.0" encoding="Utf-8" ?>.
 Inserting the tag ensures that the document will be displayed correctly
 when using non-xml capable editors (ea. text editors).
 However, trying to submit an Xml document with the byte order tag gives an
 error in the Server:
 An unclassified exception occurred.
 An unclassified exception occurred. Exception occurred in method
 MgWebLayout.ParseWebLayoutDefinition at line 293 in file
 c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\web\src\webapp\WebLayout.cpp
 The problem seems to be that the MgXmlUtil::ParseString(...) does not
 check for the bytemarks, which makes sense, as it is supposed to read a
 string.
 I am unsure where to fix this. Perhaps MgUtil::GetTextFromReader(...)
 should strip the byte marks before returning the string?
 Perhaps MgUtil::GetTextFromReader(...) could be upgraded to handle
 multiple encodings, eg Utf-16 and ISO-8859-1?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/233>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
