[mapguide-trac] #191: 1.2.0 Beta 2, GDAL and Server Crashes
MapGuide Open Source trac_mapguide at osgeo.org
Sat Jun 2 19:54:16 EDT 2007
   Reporter:  amorsell  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:
  Component:  Server    |     Version:
   Severity:  blocker   |    Keywords:
External_id:            |
 MapGuide 1.2.0 beta 2.  A GDAL based layer referencing a folder of 850 ECW
 image tiles.  This actually reasonably well and is fast enough when not
 running the server in interactive mode.  But, it frequently crashes the
 server leaving it in a completely unresponsive state.  I can simulate this
 by running two browser sessions with the same map and zooming and panning
 within the same area.  Sometimes individual images don't render, and
 sometimes a complete lockup occurs.  This is not a consistent problem with
 an one image.  The console yields the following:
 FIRST CRASH---------
 ECWDataset: RasterIO(0,1476,1566,4762 -> 566x797) - doing interleaved
 read.
 ERROR 1: NCScbmReadViewLineBIL failed.
 ECWDataset: RasterIO(9043,2764,957,3175 -> 565x798) - doing interleaved
 read.
 ECWDataset: RasterIO(0,2764,1295,3175 -> 565x798) - doing interleaved
 read.
 (5940|5912) An unclassified exception occurred.
 Exception occurred in method MgServerRenderingService.RenderDynamicOverlay
 at li
 ne 283 in file
 c:\build_bond_area\mapguide_open_source_v1.2\build_13.7\mgdev\ser
 ver\src\services\rendering\ServerRenderingService.cpp
 (5940|6036) An unclassified exception occurred.
 MgApplicationResourceContentManager.EnumerateParent
 MapDefinitions at line 214 in file
 build_13.7\mgdev\server\src\services\resource\ApplicationResourceContentManager.
 cpp
 With this message then repeated over and over until restart
 SECOND CRASH------------
 ECWDataset: RasterIO(0,0,8996,1557 -> 670x452) - doing interleaved read.
 ECWDataset: RasterIO(0,750,8996,9250 -> 1021x689) - doing interleaved
 read.
 (5544|6064) An unclassified exception occurred.
 cpp
 (5544|3832) An unclassified exception occurred.
 MgApplicationResourceContentManager.SetResourceTags
  at line 369 in file
 ev\server\src\services\resource\ApplicationResourceContentManager.cpp
 cpp
 The error.log file yields the following:
 <2007-06-02T18:41:09>                   Anonymous
  Error: Failed to stylize layer: Austin_2006_aerials_ECW
  StackTrace:
   - MgStylizationUtil.StylizeLayers line 923 file
 c:\build_bond_area\mapguide_open_source_v1.2\build_13.7\mgdev\server\src\services\mapping\StylizationUtil.cpp
 I can provide the development team full access to this server via remote
 desktop if desired.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/191>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
