[mapguide-trac] #192: two different layerdefinitionfactory.php in release
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 5 10:29:20 EDT 2007
   Reporter:  zspitzer  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  medium    |   Milestone:  1.2
  Component:  General   |     Version:  1.2.0
   Severity:  minor     |    Keywords:
External_id:            |
 there are two similiar files in the release called
 it is confusing, one is in schemareport which is a good example of the
 usage of the mapguide api in php, and the the other is in mapviewerphp
 these should be based on the same file, refactoring them to support the
 same functionality and using the same xml template files.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/192>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
