[mapguide-trac] #198: 1.2.0 RC1 Default Task Pane
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 12 01:19:10 EDT 2007
   Reporter:  amorsell     |       Owner:
       Type:  defect       |      Status:  new
   Priority:  high         |   Milestone:  1.2
  Component:  AJAX Viewer  |     Version:  1.2.0
   Severity:  major        |    Keywords:
External_id:               |
 Opening a web layout created in an earlier version in 1.2.0 RC1.  Task
 pane yields:
 Invalid argument(s): [1] = "const string&" The string is invalid and
 cannot be converted. Exception occurred in method
 MgUtil.WideCharToMultiByte at line 297 in file
 c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\common\foundation\System/Util.cpp
 This appears to be related to one or both of two custom search commands in
 the web layout.  Removing the custom command definitions from the web
 layout eliminates the errors.  Further testing reveals that starting with
 a new web layout and adding a custom search command to it will yield this
 error.  The error does not occur with other types of custom commands.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/198>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
