[mapguide-trac] #202: Daily log archiving failing to archive on a daily basis
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 12 13:39:45 EDT 2007
 Reporter:  ronnielouie  |         Owner:  ronnielouie
     Type:  defect       |        Status:  closed
 Priority:  medium       |     Milestone:  1.2
Component:  Server       |       Version:  1.2.0
 Severity:  major        |    Resolution:  fixed
 Keywords:               |   External_id:  942338
Changes (by ronnielouie):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 In an attempt to optimize the archiving check, the file modified timestamp
 would be checked for every 10th log message written.  However, this
 applies to the overall number of log messages, not for the entries for
 each individual log.  Thus, if a specific log is supposed to be archived
 daily, and if the daily boundary is crossed, and it is divisible by 10,
 then the log would be archived.  Otherwise no archiving is performed.
 Unfortunately, this logic can result in several days (or other specified
 archive interval) to pass before an archive may be created.
 To fix this, and to make the timestamp check less expensive, the timestamp
 will be cached, and the need for archive check will be performed for every
 log message.  When the log is archived, the cache will be updated so that
 logs can be archived at the specified interval.
 Fixed by submission[[BR]]
 http://trac.osgeo.org/mapguide/changeset/1810 and
 http://trac.osgeo.org/mapguide/changeset/1813
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/202#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
