[mapguide-trac] #203: Custom Search to MySQL Point Geometry error
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 12 14:58:39 EDT 2007
   Reporter:  amorsell     |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:
  Component:  AJAX Viewer  |     Version:
   Severity:  major        |    Keywords:
External_id:               |
 This is with 1.2.0 RC1 but may occur with prior releases.  Created a
 custom search command in Autodesk Studio to a layer that is a MySQL point
 geometry feature source.  Upon executing the custom search in the web
 layout, the following error is returned in the task pane:
 Index is out of range. Exception occurred in method GetItem at line 81 in
 file
 c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\common\foundation\System/DisposableCollection.cpp
 I don't know if this is isolated to this particular dataset or a global
 problem.  If you cannot replicate it I can possibly provide you with a
 dump of the table.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/203>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
