[mapguide-trac] #204: Buffer on RDBMS polygon layers fail with coordinate system conversion error
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 12 17:31:45 EDT 2007
 Reporter:  trevorwekel     |         Owner:  trevorwekel
     Type:  defect          |        Status:  assigned
 Priority:  medium          |     Milestone:  1.2
Component:  Viewer Command  |       Version:  1.2.0
 Severity:  major           |    Resolution:
 Keywords:                  |   External_id:  942789
Comment (by trevorwekel):
 I have uncovered two bugs:
 1.  !MySQL does not have an active spatial context by default.  This can
 be easily worked around by selecting all spatial contexts in the buffer
 script instead of only the active ones.
 2.  PHP does not honour the !bActiveOnly flag on
 !MgFeatureService.GetSpatialContexts and !GetLongTransactions.  This is
 likely due to the presence of a default argument in the C++ header
 definition.  The default argument will have to be removed for the API to
 function correctly in PHP.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/204#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
