[mapguide-trac] #172: Bug in Selection polygon from PostGiS (PostgreSql)
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 12 18:25:36 EDT 2007
 Reporter:  maciej.skorczewski at procad.pl  |         Owner:
     Type:  defect                        |        Status:  closed
 Priority:  high                          |     Milestone:
Component:  General                       |       Version:  1.2.0
 Severity:  major                         |    Resolution:  fixed
 Keywords:                                |   External_id:  939561
Comment (by ksgeograf):
 The new tokenizer I made, was already fixed in 3.0.0rc4 of GEOS.
 The improvement suggestion I made about using WKB instead of WKT was
 implemented in OGR 1.4.0.
 So, both the original problem has been fixed, and so has the follow up
 problem.
 Traians way of fixing the BBOX issue, also means that both OGR and GEOS
 can remain unmodified, when being used with the FDO Provider.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/172#comment:14>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
