[mapguide-trac] #209: Projection: Coordinate System web tests broken in 1.2 RC1
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 14 01:27:05 EDT 2007
   Reporter:  jbirch    |       Owner:
       Type:  defect    |      Status:  new
   Priority:  high      |   Milestone:  1.2
  Component:  Web API   |     Version:  1.2.0
   Severity:  critical  |    Keywords:
External_id:            |
 I have 1.2.0 RC1 installed in a bundled configuration (Apache/PHP) on
 Windows XP SP2.
 It appears that the web server has lost track of the location for
 GDAL_DATA and/or PROJ_LIB again.  I recall seeing this problem in earlier
 releases of MGOS as well.
 When I run any of the CS tests, such as converting an EPSG code to WKT, I
 get an error message about not being able to open the .csv file from
 GDAL_DATA.
 This appears to affect both the Web API and Map Agent.
 If this isn't just a problem with the test pages, it will badly affect the
 operation of MGOS 1.2, and absolutely needs to be addressed before 1.2.0
 Final.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/209>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
