[mapguide-trac] #212: Custom Search Scale 0.001
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 18 13:51:46 EDT 2007
   Reporter:  amorsell     |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:
  Component:  AJAX Viewer  |     Version:
   Severity:  major        |    Keywords:
External_id:               |
 When a result from a custom search is clicked on, the zoom and selection
 of that object works, but the scale of the map is 1:0.001.  This can be
 globally overridden in the ajaxmappane.templ file by changing minScale to
 something that makes more sense, such as 1000 for a coordinate system in
 feet.  But, this most likely is not desirable for other coordinate
 systems.  This should be configurable on a custom search by custom search
 definition basis or at the least configurable in serverconfig.ini with a
 setting per possible coordinate system unit (e.g. foot, meters, miles,
 decimal degrees, etc.)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/212>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
