[mapguide-trac] #213: Bad labels
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jun 18 17:01:07 EDT 2007
#213: Bad labels
   Reporter:  jrizzo   |       Owner:
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  1.2
  Component:  General  |     Version:  1.2.0
   Severity:  major    |    Keywords:
External_id:           |
 With the attached LayerDefinition, the labels look incorrect at certain
 scales.  Zoomed all the way out or zoomed in really close, the labels look
 fine.  Some scales (135 for example) show the labels as long numbers
 (pointer addresses, possibly?).  An example of a bad label & a good label
 along with the sample data set will be attached.  The feature source is an
 SDF feature source joined with an ODBC feature source (a SQL Server view).
 The ODBC feature source has been omited for security purposes.  The labels
 contain values from the extended properties.  This was working fine in
 1.1.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/213>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
