[mapguide-trac] #214: Ajax Viewer hangs when loading maps with tiled base layer groups in IE6
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jun 19 19:21:05 EDT 2007
   Reporter:  wct          |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:  1.2
  Component:  AJAX Viewer  |     Version:  1.2.0
   Severity:  major        |    Keywords:  Tiled Maps IE6
External_id:               |
 I'm having an issue with the 1.2.0 RC1 release when using the AJAX viewer
 with a map that contains a base layer group. I have a map with a single
 base layer group containing 10 layers. When rendering the map, IE6 hangs
 up while pulling down the base layer group tiles from the server. The same
 map renders correctly when using IE7 or FireFox. If I use a HTTP capture I
 can see the browser issues:
 GET
 /mapguide/mapagent/mapagent.fcgi?OPERATION=GETTILEIMAGE&VERSION=1.2.0&SESSION=
 66bc0a1a-0000-1000-8000-
 0003ffcc28b3_en_0A0032280AFC0AFB0AFA&MAPDEFINITION=Library%3A%2F%2FWCT%2FARC%2FARC_PipeWatch.MapDefinition&BASEMAPLAYERGROUPNAME=Base%20Data%20_PRE&TILECOL=19101&TILEROW=7472&SCALEINDEX=0
 HTTP/1.1
 GET
 0003ffcc28b3_en_0A0032280AFC0AFB0AFA&MAPDEFINITION=Library%3A%2F%2FWCT%2FARC%2FARC_PipeWatch.MapDefinition&BASEMAPLAYERGROUPNAME=Base%20Data%20_PRE&TILECOL=19101&TILEROW=7473&SCALEINDEX=0
 HTTP/1.1
 GET
 0003ffcc28b3_en_0A0032280AFC0AFB0AFA&MAPDEFINITION=Library%3A%2F%2FWCT%2FARC%2FARC_PipeWatch.MapDefinition&BASEMAPLAYERGROUPNAME=Base%20Data%20_PRE&TILECOL=19101&TILEROW=7474&SCALEINDEX=0
 HTTP/1.1
 But then stalls (5+ minutes). If I pull these URL's individually on their
 own, the server returns imagery very quickly (so I believe the problem is
 in the javascript on the client). I've been able to reproduce this on
 several machines running IE6.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/214>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
