[mapguide-trac] #218: Cannot add layers in web studio
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jun 20 22:02:24 EDT 2007
   Reporter:  ShadowChaser  |       Owner:
       Type:  defect        |      Status:  new
   Priority:  high          |   Milestone:
  Component:  Web Studio    |     Version:  1.2.0
   Severity:  critical      |    Keywords:
External_id:                |
 When attempting to edit maps using web studio, it's impossible to add a
 layer to the map.
 Reproduction steps:
 (using Firefox 2.0.0.4 for Windows XP SP2)
 * Install MapGuide server
 * Install MapGuide web extensions using the standard "IIS" install
 * Access web studio using a remote IP (ie/
 http://120.120.120.120/mapstudio/)
 * Add a new map. Under "Layers", select the "Groups" tab.
 * Select the "Map" root layer node
 * Click the "Add layer" button
 * Select a layer in the dialog, press "select"
 * Nothing happens - the dialog is still visible, no layer is selected and
 added to the list.
 I've marked the severity critical since web studio is unusable without
 being able to add layers.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/218>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
