[mapguide-trac] #213: Bad labels
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 29 08:47:20 EDT 2007
#213: Bad labels
 Reporter:  jrizzo    |         Owner:
     Type:  defect    |        Status:  new
 Priority:  medium    |     Milestone:  1.2
Component:  General   |       Version:  1.2.0
 Severity:  critical  |    Resolution:
 Keywords:            |   External_id:  945351
Comment (by jrizzo):
 apologies for the ties to my live data.  I have uploaded an updated
 package with these dependencies removed - the only change that should be
 necessary on your end is to modify the database connection string with the
 correct path to the .mdb
 With the latest version, I tried reproducing the issue by zooming to
 exactly 1:100 and the problem does not seem to happen at that scale.
 however, after panning and zooming in and out a little bit, the labels
 eventually go bad.  I can't find an exact location or scale that causes
 it, but it usually only takes a few seconds of navigating around for the
 labels to go bad.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/213#comment:10>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
