[mapguide-trac] #9: Java API is non-standard
MapGuide Open Source trac_mapguide at osgeo.org
Thu Mar 8 16:32:13 EST 2007
 Reporter:  jec at gatekeeper.com  |         Owner:
     Type:  enhancement         |        Status:  new
 Priority:  medium              |     Milestone:
Component:  Web API             |       Version:
 Severity:  major               |    Resolution:
 Keywords:                      |   External_id:  916041
Changes (by robertbray):
  * type:  defect => enhancement
Old description:
> The Java API generated by the SWIG toolkit does not conform to the
> standards and conventions used in Java programming. The SWIG java
> configuration should be changed to do the following
> 1. method calls should being with lowercase letters
> 2. methods should not call unchecked exceptions. Easiest thing to do
> would be for exceptions to extend RuntimeException instead of Exception
> 3. collection classes should implement collection interface from
> java.util
> 4. javadoc comments with API docs embedded into the source files. Source
> files distributed with installation so that developers using IDEs can
> leverage full power of IDE
> Note that I don't think that this can be done and still maintain backward
> compatibility with existing API.
New description:
 2. methods should not call unchecked exceptions. Easiest thing to do would
 be for exceptions to extend !RuntimeException instead of Exception
 3. collection classes should implement collection interface from java.util
Comment:
 If possible we should look at changing the code to generate both the new
 "enhanced" and old "crufty" Java wrappers. That would provide a resolution
 to the compatibility issues created by changing the API.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/9#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
