[mapguide-trac] #12: Tried FDOCore Shp and SDF Only Error from SVN 3.2.2
MapGuide Open Source trac_mapguide at osgeo.org
Sun Mar 11 17:45:56 EDT 2007
   Reporter:  anonymous  |       Owner:
       Type:  defect     |      Status:  new
   Priority:  medium     |   Milestone:
  Component:  General    |     Version:
   Severity:  major      |    Keywords:
External_id:             |
 Making install in Utils
 make[2]: Entering directory `/home/OpenSource_FDO/Providers/SDF/Src/Utils'
 source='StringValue.cpp' object='StringValue.lo' libtool=yes \
 depfile='.deps/StringValue.Plo' tmpdepfile='.deps/StringValue.TPlo' \
 depmode=gcc3 /bin/sh ../../depcomp \
 /bin/sh ../../libtool --mode=compile g++ -DPACKAGE_NAME=\"FDOSDF\"
 -DPACKAGE_TARNAME=\"fdosdf\" -DPACKAGE_VERSION=\"3.2.2\"
 -DPACKAGE_STRING=\"FDOSDF\ 3.2.2\"
 -DPACKAGE_BUGREPORT=\"http://fdo.osgeo.org\" -DPACKAGE=\"fdosdf\"
 -DVERSION=\"3.2.2\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1
 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1
 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1
 -DHAVE_DLFCN_H=1 -I. -I. -I./ -I../../Inc
 -I/home/OpenSource_FDO/Fdo/Unmanaged/Inc
 -I/home/OpenSource_FDO/Fdo/Unmanaged/Src/Nls
 -I/home/OpenSource_FDO/Utilities/Common/Inc -I/usr/include     -O2
 -DSQLITE  -c -o StringValue.lo `test -f 'StringValue.cpp' || echo
 './'`StringValue.cpp
  g++ -DPACKAGE_NAME=\"FDOSDF\" -DPACKAGE_TARNAME=\"fdosdf\"
 -DPACKAGE_VERSION=\"3.2.2\" "-DPACKAGE_STRING=\"FDOSDF 3.2.2\""
 -I/home/OpenSource_FDO/Utilities/Common/Inc -I/usr/include -O2 -DSQLITE -c
 StringValue.cpp -MT StringValue.lo -MD -MP -MF .deps/StringValue.TPlo
 -fPIC -DPIC -o .libs/StringValue.o
 /home/OpenSource_FDO/Fdo/Unmanaged/Inc/Common/NamedCollection.h: In member
 function 'virtual OBJ* FdoNamedCollection<OBJ, EXC>::FindItem(const
 wchar_t*) const':
 /home/OpenSource_FDO/Fdo/Unmanaged/Inc/Common/NamedCollection.h:112:
 error: there are no arguments to 'GetCount' that depend on a template
 parameter, so a declaration of 'GetCount' must be available
 error: (if you use '-fpermissive', G++ will accept your code, but allowing
 the use of an undeclared name is deprecated)
 make[2]: *** [StringValue.lo] Error 1
 make[2]: Leaving directory `/home/OpenSource_FDO/Providers/SDF/Src/Utils'
 make[1]: *** [install-recursive] Error 1
 make[1]: Leaving directory `/home/OpenSource_FDO/Providers/SDF/Src'
 make: *** [install-recursive] Error 1
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/12>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
