[mapguide-trac] #98: Cannot theme on joined secondary properties
MapGuide Open Source trac_mapguide at osgeo.org
Fri May 4 16:28:20 EDT 2007
   Reporter:  ronnielouie             |       Owner:  ronnielouie
       Type:  defect                  |      Status:  new
   Priority:  medium                  |   Milestone:  1.2
  Component:  Feature Service         |     Version:  1.2.0
   Severity:  major                   |    Keywords:
External_id:  928586, 838886, 793603  |
 When a feature class is created via a join, and that joined feature class
 is used in a layer definition, it is not possible to theme that layer
 based on the properties from the joined source.  Select aggregate
 functions are used to enumerate the property values, and a Fdo class not
 found error will occur when trying to retrieve the values from the joined
 secondary data.  Problem generally occurs when the secondary data is from
 an RDBMS.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/98>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
