[mapguide-trac] #98: Cannot theme on joined secondary properties
MapGuide Open Source trac_mapguide at osgeo.org
Fri May 4 17:07:30 EDT 2007
 Reporter:  ronnielouie      |         Owner:  anonymous
     Type:  defect           |        Status:  closed
 Priority:  medium           |     Milestone:  1.2
Component:  Feature Service  |       Version:  1.2.0
 Severity:  major            |    Resolution:  fixed
 Keywords:                   |   External_id:  928586, 838886, 793603
Changes (by anonymous):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 If a primary feature did not have any corresponding joined data, the
 server would attempt to set the secondary feature class name to empty,
 which resulted in 'Class not found' error.  This submission corrects this
 behavior, which allows for select aggregates to succeed when defining
 themes.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/98#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
