[mapguide-trac] #108: WFS GetFeature BBOX shorthand filter URL parameter does not work
MapGuide Open Source trac_mapguide at osgeo.org
Tue May 8 12:11:16 EDT 2007
   Reporter:  chrisclaydon  |       Owner:  chrisclaydon
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  1.2
  Component:  General       |     Version:  1.2.0
   Severity:  minor         |    Keywords:
External_id:                |
 A WFS GetFeature request made using URL GET parameters should support the
 BBOX parameter as a shorthand for a full OGC spatial filter. However, the
 web tier lacks information about the required geometry property, and
 therefore this doesn't currently work.
 The solution is to use a placeholder for the geometry property in the
 filter created by the web tier (%MG_GEOM_PROP%). This is replaced on the
 server-side with the real geometry property.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/108>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
