[mapguide-trac] #115: Oracle Feature source in UTM-4 projection does not display in Map with LL84 projection
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 10 16:33:25 EDT 2007
projection
   Reporter:  brucedechant     |       Owner:
       Type:  defect           |      Status:  new
   Priority:  high             |   Milestone:  1.2
  Component:  Feature Service  |     Version:  1.2.0
   Severity:  critical         |    Keywords:
External_id:  932662           |
 If a layer created from an Oracle feature source is in a different
 projection then the map it does not display.
 The problem is that the internal method GetLayerToMapTransform() is
 calling the feature service GetSpatialContexts() API for active spatial
 contexts only when it should be requesting all of the spatial contexts.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/115>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
