[mapguide-trac] #122: Symbolization: some more minor schema changes
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 14 05:36:55 EDT 2007
   Reporter:  waltweltonlair  |       Owner:  waltweltonlair
       Type:  defect          |      Status:  new
   Priority:  high            |   Milestone:  1.2
  Component:  General         |     Version:  1.2.0
   Severity:  major           |    Keywords:
External_id:                  |
 We need to make the following changes to the symbol definition schema:
  * update default value for !AngleControl (in
 !PointUsage/!LineUsage/!AreaUsage) to !FromAngle
  * add "Use/Match/Follow/From-!HorizontalAlignment" value (final name
 still TBD) to Justification enumeration, and make this the default
 property value
  * add optional !DataType value to Parameter element
  * remove !AllowedValues element and add next release once we decide how
 to do ranges of values
 I would really like to make these schema changes before we release.  The
 fewer changes we have to make later on the better.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/122>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
