[mapguide-trac] #123: Cannot find overload for MgMappingService::GeneratePlot()
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 14 05:47:31 EDT 2007
   Reporter:  waltweltonlair  |       Owner:
       Type:  defect          |      Status:  new
   Priority:  high            |   Milestone:  1.2
  Component:  Web API         |     Version:  1.2.0
   Severity:  major           |    Keywords:
External_id:  929288          |
 Run the !MapGuide 1.0 sample application. Select the Plot as DWF task from
 the task list. Select a scale for the plot, and click Plot. This does not
 generate any output, but creates a PHP error in the Apache log: PHP Fatal
 error:  Arguments passed did not match any overload for method
 _wrap_MgMappingService_GeneratePlot in C:\Program
 Files\Autodesk\!MapGuideEnterprise2008\!WebServerExtensions\www\phpviewersample\plot.php
 on line 72.
 Plotting the current map view, without specifying a scale, works.
 Note: a similar problem occurs with the constructor for !MgMapPlot(!MgMap
 *map, !MgCoordinate *center, double scale, !MgPlotSpecification *plotSpec,
 !MgLayout *layout).
 PHP error in Apache log is: PHP Fatal error:  Arguments passed did not
 match any overload for method _wrap_new_MgMapPlot in C:\Program
 Files\Autodesk\!MapGuideEnterprise2008\!WebServerExtensions\www\samplesphp\custom_output\multiplot.php
 on line 70.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/123>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
