[mapguide-trac] #53: php viewer address/parcel search does not show pushpin symbols
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 16 12:18:48 EDT 2007
 Reporter:  jng      |         Owner:
     Type:  defect   |        Status:  new
 Priority:  medium   |     Milestone:  1.2
Component:  Samples  |       Version:  1.2.0
 Severity:  minor    |    Resolution:
 Keywords:           |   External_id:  926776
Changes (by anonymous):
  * status:  reopened => new
  * owner:  traianstanev =>
Comment:
 The problem is that the coordinate system set in the temporary SDF file
 that holds the pushpins does not match the coordinate system of the
 Sheboygan map. The $ll84 variable in findparcelfunctions.php needs to be
 set to:
     $ll84Wkt = 'GEOGCS["WGS84 Lat/Long\'s, Degrees, -180 ==>
 +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]';
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/53#comment:8>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
