[mapguide-trac] #137: MapGuide 1.2.0Beta2 WebStudio , can't login to webstudio , confirmed real issue
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 16 20:31:41 EDT 2007
issue
 Reporter:  anonymous   |         Owner:
     Type:  defect      |        Status:  new
 Priority:  medium      |     Milestone:
Component:  Web Studio  |       Version:  1.2.0
 Severity:  major       |    Resolution:
 Keywords:              |   External_id:
Comment (by anonymous):
 Also, changing localhost to 127.0.0.1 as suggested in Ticket#97 did not
 work for me, perhaps since I'm on Linux and Ticket#97 guy is on windows.
 http://trac.osgeo.org/mapguide/ticket/97
 Replying to [comment:2 anonymous]:
 > Well, I found at least two other people with exact same problem:
 > http://www.nabble.com/Login-error-in-1.2.0-Beta-t3674061s16610.html
 > Not sure if they're also on Linux or using windows version....
 > Replying to [comment:1 anonymous]:
 > > Forgot to mention this is on Linux Redhat FC4.
 > > Replying to [ticket:137 anonymous]:
 > > From what I've found there may be some issue with the new PHP 5.2.1 or
 something but webstudio doesn't work, it won't let you log in...(using the
 correct admin password and it does work through "mapadmin" interface....)
 INVALID account/password error
 > > In fact I think make install didn't even copy the "webstudio" folder
 to webservices/www....I copied it there myself from
 mapguide-1.2.0beta2/Web/src/webstudio, even tried webstudio directory from
 previous 1.1.0 build and both do the same thing, refuses to let you login
 complaining of invalid password/user.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/137#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
