[mapguide-trac] #139: Schemareport encoding problem with tilda's
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 17 03:18:19 EDT 2007
   Reporter:  zspitzer  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  medium    |   Milestone:  1.2
  Component:  General   |     Version:  1.2.0
   Severity:  major     |    Keywords:
External_id:            |
 There is a problem with the schema report, when the xsl transformation is
 done, the tildas '~' used by king oracle FDO are decoded into '-x7e-'
 which then break the view data and view feature display.
 They fail with 'The specified class was not found.' and a Null reference
 respectively.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/139>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
