[mapguide-trac] #159: Coordinate System Overrides Not Working for ODBC or MySQL
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 23 20:18:03 EDT 2007
   Reporter:  amorsell at spatialgis.com  |       Owner:
       Type:  defect                   |      Status:  new
   Priority:  high                     |   Milestone:
  Component:  AJAX Viewer              |     Version:  1.2.0
   Severity:  major                    |    Keywords:
External_id:                           |
 This worked in 1.2.0 beta 1 but is no longer working in 1.2.0 beta 2.  I
 have a MySQL table with lat lon fields.  I created an ODBC data connection
 to it and specified these fields as the geometry.  The coordinate system
 is set as LL in Autodesk MapGuide Studio.  When viewing this data in a map
 with a different coordinate system, the data is not drawn in the
 transformed location.  However, a custom search command to the same layer
 will zoom to that points Lat Lon coordinates where they are also drawn on
 the map.
 The same thing happens if I use a MySQL data connection with lat lon point
 geometry defined in the table.  The data connection has the coordinate
 system override set to LL.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/159>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
