[mapguide-trac] #166: Login problem MapGuide 1.2 Beta 2
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 24 06:47:30 EDT 2007
   Reporter:  ksgeograf  |       Owner:
       Type:  defect     |      Status:  new
   Priority:  medium     |   Milestone:  1.2
  Component:  Server     |     Version:  1.2.0
   Severity:  major      |    Keywords:  login site admin failed .Net version iis
External_id:             |
 After removing MapGuide 1.1, and removing folder from the C:\Program
 Files\MapGuideOpenSource, I installed MapGuide 1.2 Beta 2.
 I cannot login to the Site Admin, and restarting the service does not
 help.
 Changing the ASP.NET version of the "MapGuide" folder in IIS, solves the
 problem.
 I have no clue as to why, since the Site Admin is running php.
 Also, the ASP.NET version was set to 1.1, which does not work. I don't
 know if it is possible to set the .Net version in IIS from the installer.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/166>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
