[mapguide-trac] #172: Bug in Selection polygon from PostGiS (PostgreSql)
MapGuide Open Source trac_mapguide at osgeo.org
Fri May 25 06:50:15 EDT 2007
   Reporter:  maciej.skorczewski at procad.pl  |       Owner:
       Type:  defect                        |      Status:  new
   Priority:  medium                        |   Milestone:
  Component:  General                       |     Version:
   Severity:  major                         |    Keywords:
External_id:                                |
 The problem is;
 When layer are stored in PostGis database (Postgres) and i want select
 polygon i get bad results...i can't select smaller polygon.
 SO it is problem whit concavo polygon.
 take a look on screen...
 http://img340.imageshack.us/img340/4928/bugpostgisey2.jpg
 This problem comes only with layers who are stored in PostGIS. This same
 solution whit layer from shp files are corect.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/172>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
