[mapguide-trac] #173: .Net API for MapGuide 1.2 Beta2 cannot access layers
MapGuide Open Source trac_mapguide at osgeo.org
Tue May 29 11:19:01 EDT 2007
 Reporter:  ksgeograf                    |         Owner:
     Type:  defect                       |        Status:  new
 Priority:  medium                       |     Milestone:  1.2
Component:  General                      |       Version:  1.2.0
 Severity:  minor                        |    Resolution:
 Keywords:  API layers GetLayers Unpack  |   External_id:
Comment (by ksgeograf):
 It appears that the exception is caused by the map not having the
 associated ResourceService, even though the map was opened with that.
 As far as I can see, the call bypasses the MgMap::Open, and calls
 MgResource::Open directly. This makes the the map miss the call to
 InitializeResourceService(resourceService). Not sure how to fix it though.
 Would it be sufficient to add the method to MgMap? Would that be picked up
 by SWIG?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/173#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
