[mapguide-trac] #175: Unmanaged SHP File Locations Performance Issues as More Files get Added
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 30 15:10:45 EDT 2007
 Reporter:  cgountanis                         |         Owner:
     Type:  defect                             |        Status:  new
 Priority:  high                               |     Milestone:  1.2
Component:  Server                             |       Version:  1.2.0
 Severity:  major                              |    Resolution:
 Keywords:  fdo,mapguide 1.2 beta 2, shp, dbf  |   External_id:
Comment (by cgountanis):
 Either way this is still a performance bug. You should be able to query a
 feature source (zoom by id code) and not have slower speeds due to how
 many SHP files are in the directory. When will we see this improved
 please. Have customers complaining so I am complaining to you adn Autodesk
 :-) Rolls down hill what can I say.
 In the meantime we will try the pooling and also try converting to SDF.
 For some customers SDF3 (Map2008) is not an option. Especially ESRI
 customers. Need unmanaged SHP to work FAST.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/175#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
