[mapguide-trac] #272: Improve speed of rendering engine by not using "select * from table"
MapGuide Open Source trac_mapguide at osgeo.org
Wed Oct 3 09:31:14 EDT 2007
   Reporter:  ksgeograf        |       Owner:
       Type:  defect           |      Status:  new
   Priority:  medium           |   Milestone:  2.0
  Component:  Mapping Service  |     Version:  1.2.0
   Severity:  minor            |    Keywords:  render select style
External_id:                   |
 The current render engine will load the entire row from the datasource.
 This involves a potentially large overhead, as it typically needs only a
 few columns to style the layer.
 In a test case I worked on, I was able to reduce render time from 20 to 12
 seconds, just by removing unused columns from the dataset.
 This solution does not work when the data is required for anything but
 rendering.
 For a simple fix, I propose that the render figures out what columns are
 used by looking at the scalerange condition rules and tooltip.
 It might introduce a significant overhead to preparse this data. If this
 overhead is inacceptable, the RuntimeMap could include this information,
 so that it is done once pr. map, and not at each rendering.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/272>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
