[mapguide-trac] #277: Add Fusion framework to vault for installation
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 9 16:03:17 EDT 2007
   Reporter:  chrisclaydon  |       Owner:  chrisclaydon
       Type:  enhancement   |      Status:  new
   Priority:  high          |   Milestone:  2.0
  Component:  General       |     Version:
   Severity:  critical      |    Keywords:
External_id:                |
 The web tier requires the Fusion framework, which must therefore be
 installed along with it.
 This submission will add a snapshot of all the Fusion source files, plus a
 pre-built version of the generated build folder.
 This is an intermim measure. Once Fusion has its own public SVN site, we
 will likely change the process to extract a specific version from a
 specific branch in that vault, and generate the final framework files as
 part of the build process.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/277>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
