[mapguide-trac] #282: Adding support for calculated properties in the server
MapGuide Open Source trac_mapguide at osgeo.org
Fri Oct 12 16:41:51 EDT 2007
   Reporter:  RomicaDascalescu  |       Owner:
       Type:  defect            |      Status:  new
   Priority:  high              |   Milestone:
  Component:  General           |     Version:
   Severity:  major             |    Keywords:
External_id:                    |
 The server has a support for calculated properties, but there are a few
 changes which must be done to enable calculated properties.
  - Fixed the reader MgServerSelectFeatures to support calculated
 properties.
  - Fixed Describe schema to include the calculated properties from the
 extension.
  - Fixed a defect on FeatureSource-1.0.0.xsd to support calculated
 properties without having joins.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/282>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
