[mapguide-trac] #284: Add support for FDO computed fields
MapGuide Open Source trac_mapguide at osgeo.org
Sat Oct 13 21:34:22 EDT 2007
 Reporter:  tomfukushima  |         Owner:
     Type:  defect        |        Status:  closed
 Priority:  medium        |     Milestone:  2.0
Component:  General       |       Version:
 Severity:  major         |    Resolution:  fixed
 Keywords:                |   External_id:
Changes (by tomfukushima):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 The server has a support for calculated properties, but there are a few
 changes which must be done to enable calculated properties.
     * Fixed the reader MgServerSelectFeatures? to support calculated
 properties.
     * Fixed Describe schema to include the calculated properties from the
 extension.
     * Fixed a defect on FeatureSource?-1.0.0.xsd to support calculated
 properties without having joins.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/284#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
