[mapguide-trac] #289: When a layer filter fails layer should be rendered empty
MapGuide Open Source trac_mapguide at osgeo.org
Fri Oct 19 01:27:41 EDT 2007
 Reporter:  zspitzer          |         Owner:
     Type:  defect            |        Status:  new
 Priority:  high              |     Milestone:
Component:  Resource Service  |       Version:  1.2.0
 Severity:  major             |    Resolution:
 Keywords:                    |   External_id:
Changes (by zspitzer):
  * priority:  medium => high
Comment:
 I think in terms of mapguide being developer friendly this is *really*
 important.
 A use-case like a contractor assignment application where the contractor
 logs in and is meant to see their assigned jobs on the map (via a filter)
 can lead to some fairly serious business problems, lost time, two
 contractors turning up to the same job etc.
 Any mapguide application which has completely separate customer business's
 cannot currently be guaranteed that their data is private.
 I hit this error because the King.Oracle driver fails a lot with layer
 filters, but beyond monitoring SQL on the database there is no feedback,
 beyond maybe seeing too much data.
 As an out of the box experience for someone evaluating mapguide, i would
 find this very frustrating and I did waste hours of time because of this
 myself
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/289#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
