[mapguide-trac] #291: Symbolization: Fix various problems in the stylization code
MapGuide Open Source trac_mapguide at osgeo.org
Thu Oct 25 10:26:09 EDT 2007
 Reporter:  waltweltonlair  |         Owner:  waltweltonlair
     Type:  defect          |        Status:  assigned
 Priority:  high            |     Milestone:  2.0
Component:  Server          |       Version:
 Severity:  major           |    Resolution:
 Keywords:                  |   External_id:
Comment (by waltweltonlair):
 LineBuffer::Reset was not properly resetting the bounds in the case of
 m_bProcessZ=true.  Also cleaned up some usage of DBL_MAX:
 old:  m_maxz = (-1) * DBL_MAX;
 new:  m_maxz = -DBL_MAX;
 http://trac.osgeo.org/mapguide/changeset/2318
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/291#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
