[mapguide-trac] #294: Isapi and Apache agents return incorrect status codes
MapGuide Open Source trac_mapguide at osgeo.org
Mon Oct 29 15:34:33 EDT 2007
   Reporter:  chrisclaydon  |       Owner:  chrisclaydon
       Type:  defect        |      Status:  new
   Priority:  high          |   Milestone:  2.0
  Component:  General       |     Version:
   Severity:  major         |    Keywords:
External_id:  992084        |
 The new isapi and apache modules do not return the correct status codes
 and status text when an exception occurs during request processing. These
 values need to be set correctly in order to determine when a request has
 failed, and, for example, a new session should be created to replace an
 expired one.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/294>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
