[mapguide-trac] #251: Reduce server load, response time and transfer size, when using AJAX selections
MapGuide Open Source trac_mapguide at osgeo.org
Wed Sep 5 11:37:29 EDT 2007
selections
   Reporter:  ksgeograf          |       Owner:
       Type:  enhancement        |      Status:  new
   Priority:  medium             |   Milestone:  1.3
  Component:  Rendering Service  |     Version:  1.2.0
   Severity:  major              |    Keywords:  overlay size speed selection ajax
External_id:                     |
 Currently the mapguide server operation GETDYNAMICOVERLAYIMAGE is used to
 render the map, when a selection is made.
 This requires that the server re-renders the image and transfers the whole
 image to the client.
 It would be a lot more efficient if the server only produced a transparent
 overlay image and returned that. My testing shows that it is possible to
 produce the desired image by a simple process:
 1. Edit the MapDefinition xml, and set the alpha value of the background
 color to 0 (transparent).
 2. Show the map, having only one layer visible and selectable.
 3. Select the feature in the visible layer.
 4. Toggle the layer invisible in the legend.
 The returned png is transparent and contains a nicely alpha blended
 selection overlay.
 A sample measuring indicates that the normal selection procedure requires
 350kb datatransfer and 1.2 seconds delay. The overlay-only version
 requires 7kb data and 300 ms.
 This can be implemented, either by a new operation :
 "GETDYNAMICOVERLAYSELECTION"
 or by an aditional parameter to GETDYNAMICOVERLAYIMAGE : "SELECTIONONLY".
 Eiter way, it should do the same as the current GETDYNAMICOVERLAYIMAGE
 but:
 1. Ensure the background is transparent
 2. Not render any layers, only the final selection part
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/251>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
