[mapguide-trac] #644: Problem with "building the WebServer"
MapGuide Open Source trac_mapguide at osgeo.org
Fri Aug 1 11:34:33 EDT 2008
 Reporter:  ssnc          |         Owner:
     Type:  defect        |        Status:  new
 Priority:  high          |     Milestone:
Component:  Build System  |       Version:  2.0.1
 Severity:  blocker       |    Resolution:
 Keywords:                |   External_id:  ssnc
Comment (by tomfukushima):
 Hi, I noticed that the IsapiAgent directory was missing, but it didn't
 affect me because I was building on Linux where there is no need for
 ISAPI.  You can get the code by running the following commands in a DOS
 window:
 $ cd mapguide2.0.1\Web\src
 $ svn export
 http://svn.osgeo.org/mapguide/branches/2.0.x/MgDev/Web/src/IsapiAgent
 $ cd MapAgentCommon
 $ svn export
 http://svn.osgeo.org/mapguide/branches/2.0.x/MgDev/Web/src/MapAgentCommon/MapAgentCommon.vcproj
 I recommend cutting and pasting the above svn commands.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/644#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
