[mapguide-trac] #655: API needs MgLayerGroup SetExpandInLegend Method
MapGuide Open Source trac_mapguide at osgeo.org
Wed Aug 6 15:25:13 EDT 2008
   Reporter:  amorsell     |       Owner:
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Web API      |     Version:  2.0.1
   Severity:  minor        |    Keywords:
External_id:               |
 The API has an MgLayerGroup GetExpandInLegend method, but there is no
 SetExpandInLegend method.  When programmaticly creating a new layer group,
 having it expanded when the legend refreshes is often desirable and there
 is currently no way to do this.  A good example can be seen in the
 Modifying Maps and Layers section of the developers samples.  When adding
 any new layer to the map, the resultant Analysis group is collapsed each
 time and then has to be manually expanded by the end-user.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/655>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
