[mapguide-trac] #657: Unable to load php_MapGuideApi.dll when there are multiple PHP directories in the system PATH
MapGuide Open Source trac_mapguide at osgeo.org
Thu Aug 7 16:14:52 EDT 2008
in the system PATH
   Reporter:  ronnielouie  |       Owner:  ronnielouie
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:  2.1
  Component:  Web API      |     Version:  2.0.1
   Severity:  major        |    Keywords:
External_id:  1063001      |
 When configured with IIS or Apache, the system PATH is used to find the
 location of dependent DLLS for the php_MapGuideApi.dll.  When there are
 multiple locations for PHP in the system PATH, the first PHP occurrence
 will be used which is not necessarily correct.
 To resolve this issue, php_MapGuideApi.dll and its dependencies should be
 able to load without relying the PATH environment variable.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/657>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
