[mapguide-trac] #668: cartographic stylization engine throws error with composite and line/area stylization at same zoom level
MapGuide Open Source trac_mapguide at osgeo.org
Wed Aug 20 11:13:11 EDT 2008
 Reporter:  jmanafi  |         Owner:  waltweltonlair
     Type:  defect   |        Status:  assigned
 Priority:  high     |     Milestone:
Component:  General  |       Version:  1.2.0
 Severity:  minor    |    Resolution:
 Keywords:           |   External_id:
Changes (by waltweltonlair):
  * status:  new => assigned
  * owner:  => waltweltonlair
Comment:
 In MapGuide 1.2.0, line style support in the new cartographic engine is
 not 100% stable.  That's why it's disabled by default.  If you enable it
 (via the servierconfig.ini setting) you use it at your own risk.
 Area style support was not implemented in MapGuide 1.2.0.
 Line and area styles are correctly supported in MapGuide 2.0.0.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/668#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
