[mapguide-trac] #659: WebAPI "Cannot establish connection". on different machine than server
MapGuide Open Source trac_mapguide at osgeo.org
Wed Aug 20 12:16:22 EDT 2008
 Reporter:  zspitzer  |         Owner:
     Type:  defect    |        Status:  new
 Priority:  medium    |     Milestone:
Component:  Web API   |       Version:  2.0.1
 Severity:  minor     |    Resolution:
 Keywords:            |   External_id:
Comment (by trevorwekel):
 MapGuide uses three ports for communication between the Server and Web
 Extensions.  Do the ports match in serverconfig.ini and webconfig.ini?
 Can you create a connection using telnet for all the port numbers?  Also,
 is the MachineIp and IpAddress in serverconfig.ini set to the public IP
 address of the server?  If you have installed the server as "local web
 extensions", these addresses will be set to 127.0.0.1 and external web
 extensions will not be able to connect to the services.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/659#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
