[mapguide-trac] #659: WebAPI "Cannot establish connection". on different machine than server
MapGuide Open Source trac_mapguide at osgeo.org
Thu Aug 21 01:04:04 EDT 2008
 Reporter:  zspitzer  |         Owner:
     Type:  defect    |        Status:  new
 Priority:  medium    |     Milestone:
Component:  Web API   |       Version:  2.0.1
 Severity:  minor     |    Resolution:
 Keywords:            |   External_id:
Comment (by zspitzer):
 ahh, i missed the machine IP, it's a bit confusing!
 So serverconfig.ini has two configuration variables in separate sections
 which must always be the same..
 I guess this dates back to the old site & support server stuff right?
 So regardless of the serverconfig.ini config, for simplicity shouldn't the
 web API  just use the webconfig.ini value, as you can't use any other
 values anyway.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/659#comment:8>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
