[mapguide-trac] #677: MgDbXmlException error not allowing to specify layser styling
MapGuide Open Source trac_mapguide at osgeo.org
Sun Aug 24 16:15:53 EDT 2008
   Reporter:  Andresch  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  low       |   Milestone:
  Component:  General   |     Version:  2.0.1
   Severity:  trivial   |    Keywords:
External_id:            |
 Attached is the xml code.
 I am trying to add styling to a Postgis layer, but got an error:
 An error occurred while saving: The remote server returned an error: (559)
 MgDbXmlException.:
 An exception occurred in DB XM component.
 Error: XML Indexer: Parse error in document at line, 45 char22, Parser
 message: Element ' BackgroundColor' is not valid content model:
 Exception occurred in method MgResourceDefinitionManager.UpdateDocument at
 line 601 in file
 d:\buildforgeprojects\mapguide_opensource_v2.0\build_27.16\mgdev\derver\src\
 services\resource\ResourceDefinitionManage.cpp
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/677>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
