[mapguide-trac] #796: Expression Functions(If, Lookup, Range) are not working
MapGuide Open Source trac_mapguide at osgeo.org
Tue Dec 16 10:26:58 EST 2008
#796: Expression Functions(If,Lookup,Range) are not working
   Reporter:  mgluobin         |       Owner:
       Type:  defect           |      Status:  new
   Priority:  high             |   Milestone:  2.1
  Component:  Feature Service  |     Version:  2.0.1
   Severity:  blocker          |    Keywords:
External_id:                   |
 When i execute the code in PHP with the sample data,such as :
 $resourceName =
 "Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource";
 $resId = new MgResourceIdentifier($resourceName);
 $aggregateOptions = new MgFeatureAggregateOptions();
 $aggregateOptions->AddComputedProperty("rangeTest",
 "Range(Autogenerated_SDF_ID, 4.0, 1, 100, 6.0, 100, 200, 8.0)");
 $dataReader = $featureService->SelectAggregate($resId,
 'SHP_Schema:RoadCenterLines', $aggregateOptions);
 There are such errors:An exception occurred in FDO component. Item 'RANGE'
 not found in collection An exception occurred in FDO component. Item
 'RANGE' not found in collection Exception occurred in method
 MgServerSelectFeatures.SelectFeatures at line 249 in file
 f:\mapguide\2.3.1\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/796>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
