[mapguide-trac] #804: Layer editor does not set selected schema (feature class) if the feature source has multiple
MapGuide Open Source trac_mapguide at osgeo.org
Thu Dec 18 23:46:14 EST 2008
source has multiple
   Reporter:  jng      |       Owner:  ksgeograf
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:  2.0.1
   Severity:  major    |    Keywords:
External_id:           |
 If you have a feature source that contains more than one feature class.
 When opening a layer definition that references that feature source, the
 "Schema" field on the layer editor stays at the first feature class. It
 does not get set to the actual referenced feature class.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/804>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
