[mapguide-trac] #801: Request for change the status bar to reflect the layer selected
MapGuide Open Source trac_mapguide at osgeo.org
Fri Dec 19 18:01:30 EST 2008
 Reporter:  bscott       |         Owner:
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:  2.1
Component:  AJAX Viewer  |       Version:  2.0.2
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Comment (by tomfukushima):
 I tested this out and would like to request the following changes before I
 submit.
  1. Check to make sure selLayers is not null before using it (that is,
 change line "if(selLayers.length ==1)" to "if(selLayers!=null &&
 selLayers.length...".
  1. Put up a tooltip when the user floats the mouse over the area that
 displays the selection count.  This is required now for the cases of long
 layer names which will make it so that some of the text is not visible.  I
 realize that you could select the text area and scroll the text using the
 mouse, but this is not user friendly.  Alternatively, if we could resize
 the status bar areas, that might be another solution.  Of course, there
 might be another way to solve this too.
 Thanks,
 Tom
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/801#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
