[mapguide-trac] #811: Maestro breaks down on a significantly large amount of resources.
MapGuide Open Source trac_mapguide at osgeo.org
Mon Dec 22 04:45:10 EST 2008
   Reporter:  jng      |       Owner:  ksgeograf
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:
  Component:  Maestro  |     Version:  2.0.1
   Severity:  major    |    Keywords:
External_id:           |
 We have a very large MapGuide dataset that is causing Maestro to break
 down with OutOfMemoryExceptions.
 Maestro currently loads the entire resource tree on startup. While this is
 fine for your average sized dataset, on the extremely large side of
 things. This is very ineffective.
 Maestro should either utilise the new EnumerateResources API (if supported
 by the server) or only partially load the resource tree.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/811>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
