[mapguide-trac] #163: WebStudio Has Layer and Map Preview Dependancy on 'mapviewerphp' Option
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jan 8 10:30:12 EST 2008
 Reporter:  Crispin @ IME  |         Owner:  zjames
     Type:  enhancement    |        Status:  assigned
 Priority:  medium         |     Milestone:  2.0
Component:  Web Studio     |       Version:
 Severity:  major          |    Resolution:
 Keywords:                 |   External_id:
Comment (by jng):
 This patch modifies webstudio to utilise the <DefaultTechnology> tag in
 the config.xml document.
 When a session has been established, webstudio will create the viewer
 preview url based on the default technology option.
 If 'php' is specified, the preview url will be
 http://<hostname:port>/mapguide/mapviewerphp/ajaxviewer.php
 If 'java' is specified, the preview url will be
 http://<hostname:port>/mapguide/mapviewerjava/ajaxviewer.jsp
 If 'aspnet' is specified, the preview url will be
 http://<hostname:port>/mapguide/mapviewernet/ajaxviewer.aspx
 Otherwise, webstudio will use the installed default, which is:
 http://<hostname:port>/mapguide/mapviewerajax/
 The layer, map, and weblayout previews have been modifed to use this
 calculated url, thus removing the dependency on 'mapviewerphp'
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/163#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
